Failed to find interface in mapping table.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to find interface in mapping table. Interface index requested : %p1% Local error code : %p2%
| Name | Type |
| p1 | uInt32 |
| p2 | sInt |
